Firmware x.0.12.2.1166_r2 - 20240802
bei neueren Autos müsste man schaun welche Firmware vorher vom Werk ausgeliefert wird.
Alls was unter SW Ver: 11.3 wäre theorethisch möglich.
Das sieht man nur wenn man das Radio ausbaut, auf dem Typenschild sollte folgendes stehen,
siehe Beispiel:
=> printenv
baudrate=115200
board_name=SABREBAVN
board_rev=MX6DL
bootcmd=mmc dev ${mmcdev}; mmc rescan; run loadimage; setenv zImagesize ${filesize};run loadkeybin; run mmcboot;
bootdelay=0
cma=32M
conf=notuser
console=ttymxc3
dcma=32M
defaultenv=env default -a
dm_opts=1
eraseenv=mmc erase 0x600 0x2
fdt_addr=0x18000000
fdt_file=imx6dl-sabrebavn.dtb_2
fdt_high=0xffffffff
gpu_base=0x28000000
gpu_size=134217728
hablog=off
halt=on
hwid=0b0011101010
hwvar=0x0703
image=zImage_2
init_path=init=/sbin/init.early
key_addr=0x17000000
keybin=key.bin
loadaddr=0x12000000
loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}
loadfdtproperties=fdt addr ${fdt_addr}; if test "${mmcroot}" = "/dev/mmcblk0p2 rootwait ro"; then fdt get value dm_opts / dm_opts_a; else fdt get value dm_opts / dm_opts_b; fi;
loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}
loadkeybin=fatload mmc ${mmcdev}:${mmcpart} ${key_addr} ${keybin}
loglevel=1
mem=383M
memargs=setenv memconf mem=${mem} cma=${cma} dcma=${dcma} galcore.contiguousSize=${gpu_size} galcore.contiguousBase=${gpu_base}
mmcargs=setenv bootargs "${init_path} console=${console},${baudrate} ${memconf} hwid=${hwid} hwvar=${hwvar} ${smp} ${misc} ${pclk_str} panel=${panel} rootfstype=${root_type} root=/dev/dm-0 rootwait ro dm=${dm_opts} loglevel=${loglevel} ${pstoreconf} galcore.powerManagement=0 galcore.initgpu3DMinClock=16 galcore.allocVirt=1"
mmcboot=echo Booting from mmc ...0; if run loadfdt;then run loadfdtproperties; else echo WARN: CAnnot load the DT; fi; run memargs; run pstoreargs; run mmcargs; bootz ${loadaddr} - ${fdt_addr};
mmcdev=0
mmcpart=1
mmcroot=/dev/mmcblk0p3 rootwait ro
panel=default
pstoreargs=setenv pstoreconf ramoops.mem_address=${ramoops_address} ramoops.mem_size=${ramoops_size}
ramoops_address=0x27f00000
ramoops_size=0x100000
resetenv=false
root_type=ext4
Environment size: 1930/8188 bytes
Nein, es ist ab Werk mit 6.0.11.4 ausgestattet
Wenn auf dem Typenschild 11.4 steht.
Dann ist es leider nicht möglich.
Hallo!
Ich habe die Software von 9.0.9.4 auf 9.0.12.2 aktualisiert.
Später stellte sich heraus, dass der Zugriff auf das MICOM-Menü nicht mehr erlaubt war.
Ich möchte ein Downgrade durchführen.
Ich habe auch Kommentare zu diesem Thema gefunden, aber x.0.11.6 ist das einzige Ergebnis, und da ich bereits x.0.12.2 habe, was eine höhere Zahl ist, kann ich kein Downgrade durchführen.
Kann jemand dabei helfen?
Gibt es eine Version, die auf 9.0.12.2 aktualisiert wird?
Vielen Dank im Voraus für Ihre Hilfe!
Mahlzeit,
auch hier noch einmal.
Achtung: "Aktuell gibt es nach wie vor kein zurück mehr zur 0.9 bzw. 0.10"
Vielen Dank für die Antwort!Es gibt also keine Möglichkeit, ein Downgrade auf 9.0.9.4 oder 9.9.9.9 durchzuführen? In diesen war das MICOM-Menü noch aktiv.
Hallo, ich habe einen Duster 2 aus dem Jahr 2023. Ich bin gerade von der Website zurückgekehrt, auf der auch die Software auf Version 9.0.12.2 aktualisiert wurde. Gibt es irgendwo eine Liste der Änderungen? Wissen Sie, was sich geändert hat oder was weg ist?
Wenn du von 9.0.9.x upgedatet hast, geht jetzt der Micom Zugang nicht mehr.
Eine changelog gab es noch nie bei Dacia/LG.
Mahlzeit,
Navigation Software Update (kein KartenUpdate)
Fehlerbehebung:
DAB+ (war in Firmware 11 fehlerhaft)
Interne Programme
Was sonst noch geändert worden ist kann nur der Hersteller sagen.
meister.reineke
