Update MediaNav auf 1.0.15.1.19
Hat es denn schon jemand geschafft, daß die Sprachsteuerung per Bluetooth auch mit einem Android-Smartphone funktioniert?
Has anyone managed to make voice control work via Bluetooth with an Android smartphone?
yes, after enabling it in micom test menu, you can press the voice control button on the steering wheel and give a command to your phone! With Bluetooth and after enabling google assistant in your phone! the only weird thing is that the medianav informs you that Apple Siri may collect data etc :p :p
Which button is it to enable the voice control for android. It is necessary to plug in the cable from cellphone to medianav?
Can you make a photo from your micom test menu and post it here?
no it's not necessary, only the BT connection.
the button is the SPVR (A) as seen in lajo's post
spvr-png.103921
Then where did the answer come from? From the small speaker of the smartphone or from the speakers of the MediaNav?
Also über die USB-Verbindung klappt es. Auch mit der Taste am Lenkrad.
Das Android-Auto läßt sich am Smartphone so einstellen, daß es automatisch startet, wenn es mit dem Medanav per Bluetooth gekoppelt wird. Man hat dann ein zusätzliches Navi, wenn man das Smartphone über dem Media-Nav platziert. Aber die Anzeige wird dadurch jedenfalls nicht übertragen wie bei der USB-Verbindung.
So it works via the USB connection. Even with the button on the steering wheel.
The Android car can be set on the smartphone so that it starts automatically when it is paired with the Medanav via Bluetooth. You then have an additional navigation system if you place the smartphone over the media navigation system. In any case, this does not transfer the display as it does with the USB connection.
yes it doesn't transfer the display, it would need wireless android auto (wifi) which duster doesn't have. It's just the convenience that you can have google assistant without touching the phone. The voice comes from the medianav and not the phone.
Der Mann hat recht, nach der Aktivierung dieses Parameters SPRV(A) klappt es sogar auch am alten Samsung S5, wenn auch etwas träge. Was mir aber auffiel war, daß die Google-Assistentin auf einmal lispelt wie die weibliche Media-Nav-Stimme. Das macht sie im Smartphone nicht.
Welchen Code braucht man bei der 1.0.15.1 um in den Micom zu kommen?
Ist es immer noch Manager: 9777, OK, und dann <<<<, 1757, OK?
theengineer0815
